If you use thermal paste, and it is seated correctly, it should be fine. But still track the temps as soon as you get your PC working.
If you need software I recommend this:
http://openhardwaremonitor.org/
Make sure you case has food ventilation and your temps should be fine.
Hope this helps! and good luck.
