B bbhhqqmm Prominent May 2, 2017 1 0 510 May 2, 2017 #1 Hey I had an old monitor and wanted to use it as a second one. my GPU has a DVI D and DVI I, currently I am using the DVI I. The GPU I am currently using is a GT 740 4gb vram. Anyone know if it would work with dual if i used both DVI ports?
COLGeek Cybernaut Moderator Apr 6, 2009 59,492 5,286 184,340 May 3, 2017 Solution #2 Yes, that is exactly how it should work. Upvote 0 Downvote Solution
