Can Intex Power supply Smart IT 2045 S+ 450 watt PSU run Zotac Nvidia GT 730 4Gb DDR3 graphics carD??
AlphaAnde
I have the index PSU 450 watt n I want to add ZOTAC NVIDIA GT 730 4 GB graphics card....
I want to know will it be able to handle it or not???
It Can Handle Your Nvidia GT 730 Easily...But An Advice For You Get The "Zotac Nvidia Gt 730 2GB DDR5" That'll Cost You The Same And Give 2X Performance....If You Were Looking That DDR3 Version Has 128 Bit Memory Interface And DDR5 version Has 64Bit Memory Interface But Anyways DDR5 Has Ofcourse More Bandwith And Is 2 Times Better Than DDR3 Version And DDR5 Version Consumes Less Power Too And Both Are Compatible With Your PSU....:)
A suggestion from my experience. A power supply of Intex that say 450 watt may not be actually a 450 power supply. Check for its ratings as Gold, Silver, Bronze or Platinum. If it has non of them then I would say it may not be reliable. A cheap Power supply can toast your GPU and Mother board eventually.
