Question Can my AM5 unsupported CPU cooler physically damage my PC, and are my CPU temps bad and is it because I installed unsupported CPU cooler Hyper 212x ?
eziowar
421
14
18,795
Hi, my MOBO-Gigabyte B650M DS3H, bios version FA4,cpu ryzen5 7600,cpu cooler-Hyper 212X , gpu - Asrock AMD rx 7800xt challenger oc,
everything is on default in bios. i just enabled expo. so hyper 212x cooler not officially supported with AM5 but i made following adjustments manually to make it fit to my AM5 socket-
this is the X holder of the cooler which holds the heatsink on the socket - View: https://i.imgur.com/MVZ3W0V.png
it should hold the cooler like this- View: https://i.imgur.com/YlWjDAw.png
But the issue was with AM5 that we cant install the coolers seperate backplate behind the mobo cause we cant remove the socket's default backplate. now my am5 socket already had 4 screw holes on 4 corners of the socket but the issue is 4 spring screws( 1,3,4 on above image) of that X holder too high from those socket's default screw holes and cant reach to the holes to be screwed into the holes. so i decreased the gaps by attaching my cabinet's mobo mounting screw stands into those holes like this- View: https://i.imgur.com/7IX38WN.jpeg
View: https://i.imgur.com/TV2z1ig.jpeg
now the gap between spring screws of cooler's X holder and socket's screw hole decreased significantly that they touches each other , but it was not enough and still i could not screwed those spring screws of X holder into those modified screw holes properly as either the spring screws needed to be little lower or screw holes needed to be little higher. so i manually bend all the hands of that X holder little bit( i took the X holder far way from cpu socket and full system during bending, so no other pc component got effected during the bending process). So now i could easily screwed down those X holder's spring screws into the socket's modified screw holes and after completely tightening those all 4 spring screws my heatsink was totally strongly fit on the CPU and was not even moving a bit even i applied moderate force on the heatsink(i aplied Arctic MX-4 thermal paste properly) .
View: https://i.imgur.com/iOh7S7h.jpeg
(in the above pic bracket arms seems at 2 very different heights, but that pic i took when i was middle of the screwing process , after finishing my screws everything was of same height, but i cant take the pic of current situation right now cause of my GPU blocking the site.)
then i installed 2 fans , one on each side of the heat sink in push pull configuration.
after that i ran cinebench 2024 for 10 minutes (35c room temp) and got these temps on hwinfo-
View: https://i.imgur.com/G6enoLz.png
My questions are-
1.. can my cpu or socket pins or any pc component be physically damaged any way right now or over time cause i installed the cooler like that unofficial way?
2.. are those temps of cpu and cores too bad? there's like 10c different in average temps between various cores and also atleast 16c different between coolest core temp and cpu temp. Is all of this happening cause i installed the cooler such way? if i buy a new am5 supported cooler which has same cooling power as my hyper 212x will i get way better temp results? is this better temp result than stock r5 7600 cpu cooler considering room temp is at 35c? can you plz guess roughly how much more temps would be if it was stock cooler?
3.. do i have to buy new am5 supported cooler right now and ditch this hyper 212x immediately?
  1. Nothing should be damaged by what you did, but I wouldn't expect you to have good tension for long.
  2. Even properly mounted a Hyper 212 isn't going to do a very good job. AMD's AM5 CPUs are designed to run based on a 95C maximum. temperature. I don't think the stock cooler would do any better than what you're seeing now.
  3. Yes you should buy a proper cooler, and depending on where you're located you can get Thermalright or Deepcool coolers at a rather low price. Thermalright tends to have better price vs performance, but Deepcool seems to have better worldwide availability.
