I know this has been asked a lot before but none of them has the same other components as I do so,
First of all I have a prebuilt Hp Envy 700-531nx PC and I want to upgrade my Graphics card to EVGA GTX 970 SSC ACX 2.0 so will my 500w PSU run this card?
I'm on a very tight budged so buying both the graphics card and a PSU is too much, So will the GPU work or should I just forget it?
You can check the specification of the PC here: http://support.hp.com/in-en/document/c04584199
Anyway I will list it here as well
CPU: Intel Core i7 4790 @ 3.60GHz
RAM: 2X 8GB DDR3 798MHz
Storage:
2TB Seagate ST2000DM001-1ER164 (SATA)
14GB SanDisk SDSA6DM-016G-1006 (SSD)
PSU Lable :
Storage:
PSU Lable :
