I5 7500 none k
Msi h110m vd pro
1×2133 16gb ddr4
Sapphire rx 480 nitro + 8gb
250 kingston ssd
1tb wd
Corsair 550 modular psu
Antec gx330
Arctic freezer 7 rev.2
For the record at the time i couldnt afford even a decent rig so i went budget hard and till now everything worked fineat 1080 60 hz but:
I Got myself a new tv thet will be used also as a 4k gaming screen (nu8000 55inch samsung ).
At 4k:
games like forza horizon 4 will work fine on medium settings 60 frames and wont fall below 40 frames when oc the gpu to 1400 hz.
But also some games will crush my gpu after 10 mins like ffxv low settings
And ac odyssey medium when also gpu oc and with 80% fan use
So should i upgrade my gpu to rtx 2080 even with all the hate and high price ? Or wait a bit for thet the price will go down ? And can i even upgrade with this rig?
Want to get a decent gpu thet will keep up with AAA games and wont crash.
And before you ask i fully cleaned my rig couple of times til all the dust vanished and airflow is fine .
Any advice/comment will be much appreciated
Msi h110m vd pro
1×2133 16gb ddr4
250 kingston ssd
1tb wd
Antec gx330
At 4k:
