[SOLVED] Can RTX 2060 Super work with a FreeSync monitor?
It won’t change performance in any way. Depending on the monitor G-Sync may or may not have issues with a Freesync monitor. Only some monitors are guaranteed as G-Sync compatible but many non guaranteed monitors work ok while others don’t.
Thanks, the monitor I am thinking of buying is the Sceptre C248B-144R 24"
Any recommendations?
Also, if you could check my other questions from my profile and help me out, I would really appreciate it.
