[SOLVED] Can Ryzen 5 3600 work with inspiron 5675 motherboard?
Apr 19, 2020
4
I installed ryzen 5 3600 into my pc from a ryzen 5 1400 but once I installed the r5 3600 my pc wouldn’t turn on
Dell desktops tend to be closed systems - while on most systems you could drop that CPU in after a BIOS update and be laughing. Dell controls the BIOS completely - they would not allow you to simply upgrade and subvert the planned obsolescence.
Even though the cpu is bios restricted by Dell, if the OP's mobo is actually a mainstream model, wouldn't a bios update from the vendor's site work?
Only if Dell included the microcode. If the latest BIOS is 2018, there's not much to do really. It doesn't hurt to check, of course, but Dell motherboards are typically custom jobs, not off-the-shelf.
Reactions: Phaaze88
