Question Can someone help me determine what drives I need?
Standard 3.5in drives would be mounted into a rack/frame/enclosure and that would then be inserted into the mount.
Those types of devices are generally not standard between makes/models. The drive itself is though.
This is how I received it. The description indicated that there were locks, but the drives had been removed. I was hoping it is a standard / generic type of drive.
The actual drive is standard. The part that the drive goes in and gets mounted is not.
If it was me, I would discard those things altogether.
I suppose you could pull one of those out to determine its make/model and then search for the missing part.
So the
So, there is likely a proprietary mount for a standard drive?
I may need to pull it out, as you suggested. I truly appreciate the help!
I'm not opposed to getting rid of it, but resolving hardware issues with an operating system is definitely not my specialty :)
I would vastly prefer to add a ssd drive (M.2, I think it is called)
What are the specs for this system (make/model of all installed components)?
Your case may actually have internal mounts for SSDs/HDDs, and those could just be disconnected/ignored.
From the listing:
RACK MOUNTED WORKSTATION SERVER CORE I7-3960K 24GB RAM ASUS MB P6T7WS GTX 780
INTEL CORE I7-3960X 3.38GHZ PROCESSOR WITH LGA2011 AND HEATSINK W/FAN
06G-P4-3791-KR GeForce GTX Titan Black 6GB 384-Bit GDDR5 PCI Express 3.0 2 DVI/ 1 HDMI/ 1 DisplayPort Video Graphics
DVD-ROM DRIVE,
EXTERNAL HARD DRIVE PLUG IN DRIVES (NOT A HARD DRIVE, FOR PLUGGING IN EXTERNAL SPECIALTY DRIVES!) W/LOCKS, NO KEY
ASUS MOTHERBOARD, P6T7WS SUPERCOMPUTER
SECONDARY NETWORK CARD
3RD NETWORK CARD W 1000BIT (UP TO GIGABIT)
3 INTERNAL FANS, 2 EXT CASE FANS
UP TO 4 HARD DRIVE BAYS, 4 ONBOARD USB SLOTS
COOLERMASTER 1200W SILENT PRO GOLD
RECENTLY DECOMMISSIONED FROM GOVERNMENT/LARGE COMPANY, PULLED FROM WORKING USE IN CLEAN ROOM ENVIRONMENT. OUTSIDE HAS GENERAL SCRATCHES CONSISTENT WITH USE.
