I found this wire at home
and I can't understand how to use the USB part of it. I connected this end to my home router(it is a small thing that gives wifi)
and this end to my laptop
using this TP-Link adapter
and it works fine. But when I connect the usb to my laptop and disconnect the adapter then it does not even get identified. It does not show up in USBView(Windows 10 SDK). I am guessing I need to download some drivers as the TP-Link adapter has its own driver but the cable does not install its own.
So can anyone help me in identifying the cable or if I need some drivers then sending me a link to them.
I'll also write down here whats written on the cable.
E2581086 (UL) C(UL) CM 75°C UTP 4PR VERIFIED CAT5e 350MHz TIA/EIA-568B.2 FT4 ETL PATCH CABLE BROAD
