N NassimHC Reputable Dec 25, 2014 66 0 4,640 Apr 23, 2015 #1 I plan on buying a gigabyte 270 OC. I will build a computer will 2 4gb ram modules, 1 7200rpm hdd, and an FX 6300. Is the TS 550w enough?
Solution herrwizo Apr 23, 2015 It will be more than enough, with ample headroom (you will be using 350W max under full load). This is an excellent quality PSU, get it.
JQB45 Splendid Jun 23, 2006 3,599 51 24,040 Apr 23, 2015 #2 I believe 550W will be fine. To get a good estimate of your power usage enter your parts on pcpartpicker.com. It gives a good wattage used estimate. Upvote 0 Downvote
herrwizo Illustrious Feb 17, 2009 5,149 43 40,240 Apr 23, 2015 Solution #3 It will be more than enough, with ample headroom (you will be using 350W max under full load). This is an excellent quality PSU, get it. Upvote 0 Downvote Solution
N NassimHC Reputable Dec 25, 2014 66 0 4,640 Apr 23, 2015 #4 Thanks for the replies guys. I read a shady review of a 270 which claimed it used 270w under load. Thanks for the clarification Upvote 0 Downvote
herrwizo Illustrious Feb 17, 2009 5,149 43 40,240 Apr 23, 2015 #5 They most likely measured the entire system, not only the card. This card uses approximately 150W, give or take 20. Upvote 1 Downvote
