Can Work with 6 Pin to 8 Pin Molex Connector for Asus Strix GTX 1060 6GBOC
Sayooj js
23
Hi,
i brought new ASUS STRIX GTX 1060 6GBOC (8 pin Power connector),i have 650W 6pin molex power connector PSU,and i brought a new 6 Pin to 8pin molex connector from ebay, gpu still working,and RGB (slowly dim Aura RGB Red light,when turn on then flash White).but no display,when i connect the Graphics card with AGP, but i cant hear any beeps.(also can hear one beep to turn on pc generally)
Thanks for answering :) I have Avertek 650W PSU, iam found new problem i have Dell ST2220M Monitor.iam connected with Graphics card using by DVI -D to VGA Converter.. the converter unable to work... its also causing for my PC booting,? (i dont want monitor,at least a starting beep)
DVi to VGA converter will not work with this GPU unless it is active adapter. But since your monitor has DVI port, you should instead use DVI to DVI cable.
Can't find any info on that PSU (other that basic stats, which look good enough to power 1060) so not sure if it could be the cause.
Anyway, one problem at a time. Connect the monitor with right cable first. If it would still not start, then you need to test your GPU at other machine. Also, if your motherboard has integrated graphics, or you have other GPU, use that to check if you other components still work as they should.
Iam using both Board.. iam tested with GIGABYTE GA H61M-S1 + i5 3470 and Acer H61H2-AM + i5 2400 Both have same problem :??: i have another doubt, if will not give up ATX 12v Supply(Motherboard 4 pin Molex ).. board should work with properly?
