Hello,
I’m currently in the works of rebuilding my
PC into the Cooler Master SL600M.
Everything was going great until I realized my cpu cooler could not fit in the case. I use a Kraken x62 and the top 280 radiator just doesn’t have enough clearance with the board (the fans technically don’t), only 240 and 360 supported. I should’ve done more research earlier.
Regardless I’ve got my rgb fans on my radiator and I’m not ready to give up on it just yet.
My questions is can any one of you help me find a extension bracket for a 140mm fan?? My idea was to use a bracket to push the fan just a tiny bit to the front of the case so that it doesn’t bump in with my motherboard. Does such a bracket exist?
Any help would be greatly appreciated.
