Can you place a 140mm Liquid cooler in the front of case?
willo101
9
Hello, I have a Corsair SPEC-01 tower Mid ATX. I want to get a liquid cooler to put into it. My problem is only the front 2 fan spot will fit 140mm. Should i just buy Corsair H105 Extreme liquid cooler or a Corsair H115i and put it in the front of the case. That is another question I need help with. Can you put a liquid cooler radiator in the front of the case and not on the top because my case only have two 120mm top fan spots. I'm getting a I7 8700k can a H60 and I am wondering if the H60 is enough for i7 8700k. So, should I stick with the H60 or get H105 120mm, or H115i 140mm and put it the front of the Corsair SPEC-01 case. Thanks
My new build is going to be (Already bought the stuff waiting for it to come in the mail):
Intel i7 8700k
Gigabyte AUROS Gaming 7
EVGA 600w 80 plus PSU
EVGA GTX 1080 8gb
16GB G Skill 3200 DDR4 RAM
Depends on cooler, CM Nepton 140XL for instance has holes for mounting 120mm fans too so it should be able to be fastened in a 120mm fan place. All that's left is to find out other dimensions.
