Tried installing a new cooler (Corsair Hydro Series H60 AIO Liquid CPU Cooler). Tried using a new thermal paste (ARCTIC MX-4). Replacing the thermal paste worked for a bit - reduced the temperature to idle 54 degrees. But I applied the paste on June 19th, about a month ago, and now my computer is crashing due to CPU overheating (went up to 100 degrees celcius). I was running Monster Hunter World in High Graphics with OBS running. I've tried tightening the screws holding the cooler but no difference.
This is driving me nuts. I'm more than willing to replace the CPU if you think upgrading the CPU from i5 7600k will fix the issue. Or do I need a better cooler? Or is it possible that there is insufficent contact between the cooler and the CPU due to a faulty motherboard design? I have Gigabyte LGA 1151 Motherboard. If I have to buy a new motherboard and basically start from scratch, so be it!
CPU is at < 1.2 V
My Fan RPM: https://ibb.co/rMdvcKK
Here are my fan placements:
https://ibb.co/TMz2r4d
https://ibb.co/J5zk4L7
https://ibb.co/Vg9M4ts
Just need a best educated answer so that I don't buy too many unnecessary parts.
Edit:
Took a look at the performance and it seems like CPU utilization is 88% while GPU utilization is 12%. GPU is way too underutilized.
CPU is at < 1.2 V
Edit:
