Canon Print Preview problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I have re-installed my Office 2003 Professional suite but the problem
remains. I can preview in each individual application using that
application preview option as I can in Paint Shop Pro and all other
applications. It is only when I select print that the Canon starts to
print immediately without showing the Canon Print Preview screen even
though this has been selected in Print Preferences.
Johnnie
Byte Wrote:
> It is not the printer, it is the app you are using. Check for options
> or tools
> to reset.
> "johnnie" wrote:
> I have a Canon PIXMA ip 5000 printer connected via a USB port to a
> Dell
> Dimension 4700 Series under XP Pro SP2. The Print Preview option on
> the Printer Preferences page is checked and this used to produce a
> preview display whenever the printer print option was selected in any
> application program (e.g Word 2003, Excell 2003, PaintShop Pro 9
> etc).
> Recently, this preview fails to function and when a print option is
> selected the page (s) print immediately. If I connect the printer to
> my laptop also running XP Pro SP2 on a usb port the preview functions
> normally. I have identical software on both machines (as far as I
> can
> tell), but it seems that either the print preview attribute is not
> being saved or there is a conflict with some other program. I have
> uninstalled the printer and driver and reinstalled but it makes no
> difference. All Windows XP updates are installed on both machines and
> the Canon driver is their latest available. This is driving me mad!
> Can anyone suggest something to try?
> Johnnie
> johnnie
johnnie
You may have selected "Show Print Preview" in the printer Properties, but
after you check the block did you click Apply and OK to set and save settings?
If you did and still have the problem, click the Factory Settings button.
If that
doesn't solve the problem, uninstall and reinstall the printer, the file to
show
print preview may be corrupt or did not install.
> Johnnie
> > or tools
> > to reset.
> > Dell
> > etc).
> > can
> > Johnnie
> > johnnie
> johnnie
