Canopus Dv Storm2-Pro and Adobe Premiere Pro 1.5 / NO PC s..
Paul
Splendid
Mar 30, 2004
5,267
Archived from groups: rec.video.desktop (More info?)
I’m working with several AVI files that I have loaded on to
Premiere Pro 1.5 choosing the Canopus DV-NTSC preset
and I don’t have playback audio through my computer
speakers.
The audio (and video) play just fine on the TV monitor I have
connected to the DVStorm, but I need Premiere to also play
through my computer speakers.
The Playback Settings tab, Under Audio Playback, to select the
"Play Audio on Audio Hardware” option does not show when the
Canopus DV-NTSC preset has been selected, and I notice that in
the preferences/audio hardware that "Adobe default windows sound"
is the only option available. ( I have an Extreme Series Intel
D925XCV motherboard, with built-in Intel High Definition audio –Realtek-)
When I try loading the same AVI files selecting the standard DV-NTSC
preset (not the Canopus), the sound plays fine on both the external
TV monitor and the PC speakers, and I believe audio should work
the same when Canopus DV-NTSC preset has been selected.
I’ll appreciate any help regarding this matter.
Thanks in advance.
Paul
G
Guest
Guest
The DVD Storm 2 Pro has its own audio hardware. System sound hardware is
not supported.
"Paul" <paulXX@hotmail.com> wrote in message
news:xpGdnbnuqJP3XWjcRVn-hg@giganews.com...
> I'm working with several AVI files that I have loaded on to
> and I don't have playback audio through my computer
> speakers.
> "Play Audio on Audio Hardware" option does not show when the
> D925XCV motherboard, with built-in Intel High Definition audio -Realtek-)
> I'll appreciate any help regarding this matter.
> Thanks in advance.
> Paul
G
Guest
Guest
I too have much the same setup - you have to use the audio output from the
Storm card itself.
The problems I have are:
1. The sound is in mono from the Storm output - always has been even with
Premiere 6.x - this doesn't affect the actual footage.
2. The sound needs to 'catch up' when played from the timeline - so I have
to set the Storm buffer settings to quite low - much lower than I would
like.
Anyone have the same problems of above?
Jonathan
> speakers.
> Thanks in advance.
> Paul
Paul
Splendid
Mar 30, 2004
5,267
Thanks for your help Alpha.
I was wandering about having the sound on both my PC and my
TV-monitor because I believe it should work, as it dos when
I'm working with Scenalizer Live, but as you say, it seems this is the
way Canopus designed how the DVStorm2 works whit its
Premiere plug-in installed.
I'm going to check the Canopus forum to
learn what other Canopus users are saying, but for
the moment I can work with my TV-monitor always on, or I can
also connect an "Y" splitter adapter on the audio out connector of
my DVStorm, connecting both the line out cable to the TV and
the one that connects my PC speakers.
Regards,
Paul
"Alpha" <logos1@trip.net> wrote in message
news:10vbi90goo4f7bb@corp.supernews.com...
> not supported.
>> speakers.
>> Thanks in advance.
>> Paul
Paul
Splendid
Mar 30, 2004
5,267
Have you checked the following setting Jonathan?:
Project Settings >> Default Sequence >> Audio >
> Master Stereo?
Probably you have the setting on "mono".
Hope I helped.
Paul.
"Jonathan Warner" <jonathan@thewarners.clara.co.uk> wrote in message
news:1106652344.28340.0@sabbath.news.uk.clara.net...
>Storm card itself.
> like.
> Jonathan
>> speakers.
>> Thanks in advance.
>> Paul
Paul
Splendid
Mar 30, 2004
5,267
I was wondering about having the sound in both my PC and my
TV-Monitor because I believe it should work, as it works when
way Canopus have designed how the DVStorm2 works whit it's
I'm going to check the Canopus forum as soon I find some time to
learn what other Canopus users are talking about there, but for
my DVStorm, and connecting both the line out cable to the TV and
Regards,
Paul
> not supported.
>> speakers.
>> Thanks in advance.
>> Paul
Paul
Splendid
Mar 30, 2004
5,267
Regards,
Paul
> not supported.
>> speakers.
>> Thanks in advance.
>> Paul
Paul
Splendid
Mar 30, 2004
5,267
Regards,
Paul
> not supported.
>> speakers.
>> Thanks in advance.
>> Paul
