I bought the card second hand. It came with the box but didn't have the power adapter where you plug two six pin connectors and on the other end you have 6 + 2 pin connector that go into the 8 pin power slot on the PCB of the card.
My PSU is 900 watts, it has loads of 6 pin connectors but not the 6 + 2 pin connectors.
I checked the internet for the adapter that comes with GTX 970 card but the closest thing i could find to it was this 2 x 4 pin molex male connector to 6 + 2 pin power connector
My question is, would this be suitable replacement for the 6+2 pin adapter ? or would i need specifically the 2 x 6 pin connector to 6 + 2 power connector ? If that is the case, can someone please share a link with me where such adapter can be purchased. I really don't want to be buying a new PSU as this one has already costed me good few dollars
Kind Regards,
Chilintano
Kind Regards,
Chilintano
