Specs:
i7-6700K
AMD R9 390
ASUS Z170-A
Corsair H110i GTX (replaced stock fans with Silent Wings 2 140mm PWM)
Corsair Vengeance 16GB 3000MHz DDR4
Before I replaced the fans on the radiators from the stock ones to the Silent Wings 2, I could control the fan speeds in Corsair Link without a problem.
After replacing them, I could no longer control the fans, even though the wiring is exactly the same as it was before.
1.The two Silent Wings 2 PWM 140mm fans are connected to a splitter that is connected to the AIO cooler. (One connector has 3 pins and the other has 4 pins. Both fans have 4 pins).
2. The AIO cooler also has a SATA cable that is connected to a SATA port.
3. The AIO cooler has a 3 pin connector that is connected to a 4 pin CPU_FAN header (the CPU_FAN header only gives RPM data to the computer).
4.The AIO cooler has a mini-USB cable that is connected to a USB 2.0 connector.
Corsair Link shows MB fan is spinning at 770-890 RPM
AI Suite 3 shows CPU fan is spinning at 770-890 RPM
Both are referring to the same fans.
Ideas?
i7-6700K
AMD R9 390
ASUS Z170-A
Ideas?
