Hello everyone, so in short I had a Gigabyte A320M S2H on which I could enable xmp and run my two Corsair ram at 3600 MHz. Now I exchanged it for a Gigabyte A320M S2H V2 CF, and on this I can't enable xmp, if I do the system reboots right away and I see the ram are set to 2133, I can't even change the frequency manually without xmp, I tried resetting the CMOS battery and update the bios to the latest version. what could I try? the motherboard is the only component I changed, everything is the same as before. Thanks in advance!
