alright. so my great jetway m-atx sets my clock speed to 800mhz when cpu ratio is set at auto in bios..when i manually set it to x16 for 3.2ghz stock speed, i get the BSOD on startup. I dropped it down to x14 for 2.8 speeds, but get the BSOD around 20 minutes in windows. x12 seems stable :/
I'm using windows xp pro 32-bit When I first built the system I had a failboat psu (antec 620 eco) that emitted a battery stench/turned off
videocard: his hd 4890
ram: 4gb 2x2gb ddr2 800
optical: blu-ray
hdd: 1 7200rpm 500gb
1 80gb ssd
no sound
current psu (brand new): http://www.newegg.com/Product/Product.aspx?Item=N82E16817171038&Tpk=coolmaster%20550w
motherboard:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=jetway+am3&x=0&y=0
theres mention of my mobo only being able to run 65w cpus, but others are arguing that it can handle 65w+ cpus? I bought this as a combo deal with my 955 through newegg. I'm guessing its either my volt settings through the bios, the psu, or the mobo :/ here are screens of my bios, and temps
@ 2.8ghz during 3dmark06 cpu bench:
stable @ 2.4 :
Last build was in '05, so I'm pretty newb to all this stuff, I'm getting it..but man
optical: blu-ray
1 80gb ssd
no sound
motherboard:
stable @ 2.4 :
