I'm using a Hauppauge Colossus 2 to record from both my Xbox One and my STB via a HDMI switch that's connected to the capture card. I have zero issues regarding audio when it comes to recording and viewing the preview through software such as OBS. My issue pertains to the output, where I have the capture card connected to one of my monitors.
As of right now, I have two separate 3.5mm cables from my devices to Line In and Mic In and enabled listening to them through Windows 10 respectively. The connection from the STB to my PC is viable for my set up. However, the way I'm currently getting audio from my game console is through the audio port on the bottom of controller. This works well as far as the sound quality goes, but the long cable from the controller kind of makes things awkward.
This is certainly not something that I would unable deal with, but I want to make sure I'm not missing any other possible solutions before having to totally resort to this.
I've tried running one single audio cable from the audio output on my monitor to the hdmi switch, thus eliminating the need for two separate cables.. this just resulted in poor audio quality. Also, there's a several second delay from the capture card input, so using that as an audio source is out of the picture as well.
Relative specs:
Capture Card: Colossus 2
Capture Card Monitor: ASUS VG248QE
DAC/Amplifier: FiiO K3 DSD256
HDMI Switch: Fosmon HD8198
Graphics Card: RTX 2080 TI
OS: Windows 10
Any help/suggestions would be appreciated!
Relative specs:
OS: Windows 10
