Capture-problem
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    HD
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I´v problem to capture from vcr.
Hardware is a panasonic taperecorder playing avhs casette.
For capture I use PC with card Pinnacle DV-500 with breakoutbox
to Premiere 6.02
When I try to capture thru capture movie under arkiv in premiere, I
can do so but left side is not good on the movie. It looks good on tv
when I capture. But when playing film from PC( view clip in premiere
or wmp in windows) it has not a good left edge also some disturbance
in botton.
My settings in premiere project is
general=editing mode Pinacle avi pal 25/sek
video= 720-576 and D1/DV PAL
keyf. and rend = lower field first
Capture=Pinnacle-AVI capture (input composite,format PAL open DML,
Audio 48 khz, General =primary surface
Anyone who can help me to make it better?
/Emmi
>to Premiere 6.02
>in botton.
That is normal. You don't see it on the TV because the rough areas
are in the overscan part of the image which doesn't show up on the TV.
I think you'll have to re-encode it while masking the ugly areas (if
you're planning to put in on DVD, you'll need to re-encode it anyway).
I'm not familiar with your software, but I know it can be done with
TMPGEnc.
