Case and Mobo Help! First game pc build!
hulkjesus
4
I'm trying to build my first ever computer on this upcoming black friday/cyber monday! I'm pretty sure this motherboard will fit and work well in this case but I just have a couple quick questions! Here are the specs first!
Case - https://www.newegg.com/Product/Product.aspx?Item=N82E16811147275&cm_re=rosewill-_-11-147-275-_-Product
Mobo - GIGABYTE Z370 AORUS Gaming 7
https://www.newegg.com/Product/Product.aspx?item=N82E16813145036
I'm sure the mobo will fit and all it just makes second guess with the notice inside the "Specs" tab in the case description. States "NOTICE: Please make sure your motherboard equipped with on-board USB 3.0 socket before purchasing." I couldn't find anything in the mobo that says it or in any of the ones I've looked at.
Basically if I don't have any 3.0 sockets I just can't use the usb and audio jacks on the top of the computer?
Or if you guys have any recommendations on other (Intel I7s z370) Mobos for a GTX 1080ti, 960 evo samsung 500gb ssd. Basic gaming computer you know. Throw out all the info at me you want. I'm open to all criticism and info you feel like!
My budget is 2,000ish so not to worried about pricier parts. I want quality. :)
Thanks in advance guys! I'm excited and a bit nervous too!
Internal I/O Connectors
Onboard USB
1 x USB Type-C port, with USB 3.1 Gen 2 support
1 x USB 3.1 Gen 1 header
2 x USB 2.0/1.1 headers
You are fine.
850 evo will perform similarly but cheaper. List your whole rig please?
