[SOLVED] Case fan does not spining
Jan 26, 2022
Just get my PC back which I sent to an IT shop for repair & change pc case. I found that the case fan's light is on but it does not spinning. The exhaust fan at the rear, cpu's fan and gpu's fan are working.
Here is the spec:
Motherboard - Asus Prime H310M-D R2.0 (https://www.asus.com/Motherboards-Components/Motherboards/PRIME/PRIME-H310M-D-R2-0/techspec/)
PC Case - Asus Tuf GT301 (https://www.asus.com/Motherboards-Components/Gaming-Cases/TUF-Gaming/TUF-Gaming-GT301/)
Power supply - Forget which model but I remember it is 500W
I would like to know does the motherboard support the case fan or not.
Reactions: je35207
There's only one case fan header on the MB so for 2 case fans there has to be a splitter for both to work. Something like this
https://www.amazon.com/-/es/JBtek-C...4?keywords=pwm+splitter&qid=1643277251&sr=8-4
So can i use a splitter to connect one front fan and rear fan to the fan header or not recommend to do that? I guess one front fan (intake) and rear fan (exhaust) is enough for current spec.
