most case fans haveeither a 4 pin molex connector, or a 3 pin connector for your motherboard. A lot of the time, when it is the 4 pin, it is a pass thru connector.
And IIRC, the xaser series has a built in fan selection switch, and most likly you can plug multiple fans into it, than plug the switch in.
All in all, you may need a few spliitter cables, but I would wait until you get it all up and running first. Plus, think about it, do you need all of those fans? That could get a bit loud! Are you overclocking and are you gonna have this thing in a warm room? If so, then all those fans may be needed, but probably not. I try to have the least amount nessasay when it comes to them. Whatever keeps it cool and quiet is usualy best.
<A HREF="http://tekkoshocon.com/" target="_new">http://tekkoshocon.com/</A> Southeast Pennsylvania gets an Anime Convention!
