To get really accurate responses, post these pieces of info:
1. Exactly what maker and model of mobo. With this we can find out what methods its mobo fan headers use to control fans, and advise on how to set fan header options in BIOS Setup.
2. Exactly what makes and models of fans. With that we can look up their power requirements. Most common fans can work with three (sometimes even four) on one header using splitters, but some fans use much more current than "common" fans. And yes, "stacked" splitters are OK if the total current pull is low enough.
With that information also we can advise whether you are better using Splitters or a Hub. These two types of device look similar but are different in important ways.
