M mintygreen415 Prominent Feb 9, 2018 2 0 510 Feb 9, 2018 #1 I bought a single NZXT Aer RGB fan, and a bundle pack with the Hue+ and 2 Aer RGB fans. I daisy chained it and then I plugged into mb only one fan is spinning...? Help....
Solution I I Imacflier Feb 9, 2018 Try plugging in each fan separately. If, for example, the second fan in the daisy chain is bad, only the first fan would operate. Larry
I Imacflier Distinguished Jan 19, 2014 456 7 18,865 Feb 9, 2018 Solution #2 Try plugging in each fan separately. If, for example, the second fan in the daisy chain is bad, only the first fan would operate. Larry Upvote 0 Downvote Solution
