Case fans
So, the Antec 902 has a 200mm fan at the top, with blue LEDs. I don't want to hassle with swapping the LEDs out, but is there any place, thats trustable, that sells 200mm white led fans? I checked Newegg and Performance-Pcs, and nada. So if there is none, how do you swap out LED's?
Bare LEDs have a flat spot on the base as shown in the diagram below from Wikipedia. What you want to do is to use that as a guide to which LED wire to hook up to which wire on the fan assembly. Whichever wire was hooked up to the flat side of the old LED needs to be hooked up to the flat side of the new LED.
