Hello
I can't find one with part picker that features both of the following (they come with USB 3.2 Gen 1 Type-A instead of Gen 2 Type-C):
I can't see one with
or
pangoly.com
Help?
Is USB 3.2 Gen 1 Type-A the same as USB 3.2 Gen 2 Type-C? Meaning I can get a case with USB 3.2 Gen 1 Type-A and is compatible with this motherboard's USB 3.2 Gen 2 Type-C?
I google and it appears so: "
Is USB 3.2 Gen 1 the same as USB-C?
Both USB Type-A and USB Type-C connectors are used to facilitate 5 Gbps and 10 Gbps (USB 3.2 Gen 1 and Gen 2) connections, and USB Type-C is also used to facilitate the 20 Gbps (USB 3.2 Gen 2×2), 40 Gbps (USB4), and 80 Gbps (USB4 V2) connections."
I also looked at: https://www.onlogic.com/company/io-hub/usb-type-c-and-usb-3-1-explained/
and it seems so. Confirm please?
It should also be compatible with Cooler Master MASTERLIQUID ML240L RGB V2
P.S. Asus has a specialized case at about 150 which is a bad price
- USB 3.2 Gen 2x2 Type-C
- USB 3.2 Gen 2 Type-C
or
Compatible cases with ASUS TUF Gaming Z790-Plus WiFi
Get compatible cases for ASUS TUF Gaming Z790-Plus WiFi. Filter by Type, Color, Includes Power Supply, External 5.25" Drive Bays, Internal 2.5" Drive Bays and more.
Help?
