[Moderator note: Changing to Solved per Post #5.]
- MOBO; Asrock B450M-HDV R4.0
- Case: AeroCool Streak
I have moved my components from an HP case to a new one, everything is working fine including the power button and the 2.0 & 3.0 USB ports and HD audio, except the RGB light lines on the front of the case, i don't have any RGB fans but i would like to turn on the case lights if possible it has two straight ARGB lines, i press the reset button that allegedly change the colors according to advertizing videos but nothing happens,
here's a shot of the case user manual if could you show me which cable is responsible for tuning the case lights on? is there any solutions please, or is it that my motherboard just not supported? thanks.
