W w41g872 Distinguished Feb 5, 2016 78 0 18,560 May 14, 2016 #1 I need a case that can fit an ATX mobo, and is all white (if there is any other color like black, they should be easy to be spray painted), and a clear side panel. Is there any recommendations? Thank you for helping me out.
Solution Z Z ZurielV May 14, 2016 There are so many options.. literally.. I'd check out newegg's selection to start.. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007583%20600545969%20600546033%20600006331%20600006505
Z ZurielV Reputable Oct 7, 2015 5 0 4,520 May 14, 2016 Solution #2 There are so many options.. literally.. I'd check out newegg's selection to start.. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007583%20600545969%20600546033%20600006331%20600006505 Upvote 0 Downvote Solution
