M moemoehott Reputable Mar 23, 2015 13 0 4,510 Apr 7, 2015 #1 i need help finding a good case wath great air flow but wath Only usb 2.0 in it
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Apr 7, 2015 #2 You'll need to find an old cheap case. You do know that usb2.0 devices will work in usb3.0 ports? And that most cases have two usb2.0 and two usb3.0 ports these days? And that your motherboard (at the back of the PC) will also have usb2.0 ports? Upvote 0 Downvote
M moemoehott Reputable Mar 23, 2015 13 0 4,510 Apr 7, 2015 #3 i7Baby : You'll need to find an old cheap case. You do know that usb2.0 devices will work in usb3.0 ports? And that most cases have two usb2.0 and two usb3.0 ports these days? And that your motherboard (at the back of the PC) will also have usb2.0 ports? will my old motherbord das not have a 3.0 header on it and i ues most of my ports in the back but i stell ues the ones in the front eatch day Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Apr 7, 2015 #4 Time to upgrade then. You can always buy a pcie to usb card and a bay device with more usb ports in it. You can even do usb3.0 with this. Upvote 0 Downvote
