CCC Catalyst control center not opening in win 8.1 64-bit
Dan_plotly
I have tried uninstall and re-install of a few versions. Specifically 14.4 and 14.7 (beta). No luck. I am running an amd radeon 7800 graphics card. Any advice?
Fixed it by UN-installing everything AMD and restarting, (yet again). Downloaded and ran the AMD CleanUtility, (link below), then restarted, (yet again). Once the machine came to life again. I went straight to the AMDsite, proceeded to the drivers page, and downloaded the 14.7 beta driver pack. I installed the package, (yet again), (Making sure to UN-tick the AMD Gaming Evolve CRAP!). Then, I restarted, (you guessed it.., yet again).
When she came to the AMD Catalyst Utility started on it own!!! YAY!!!
(Granted it was last in the start-up list, but that is easily fixable with the proper utility to change your start-up order)!!
(Then, created a Restore Point!)
Good Luck!! hope this one helps...
3 days no response. Getting pretty frustrated. Put in 5 hours Its almost a quest at this point. I need to solve this solution for my sanity. I'm going to keep trying new things. P.S. I hate win 8 and 8.1
I am having the same issue. I have looked at a few threads and have done everything they say./ Restore point from 2 days ago when this started. I downloaded the newest 14.4 and installed. It installed Gaming Evolved CRAP, had to restore to the day before that. (NBD). Downloaded fresh driver package, installed, (WITHOUT Gaming Evloved CRAP), and still same issue... Catalyst just starts to load, get the "hourglass"... then the screen flicks and the solid "Blue circle".... then it just stops! Nothing! I am at a loss right now.
Here is a Sandra of my System
SiSoftware Sandra
ID
Host Name : DERRY
Workgroup : IRELAND
Computer
Model : GigaByte
Serial Number : xxxxxxxxxxxx
Chassis : GigaByte Desktop
Mainboard : GigaByte Z77-HD4
BIOS : AMI (OEM) F1 10/24/2012
Intel vPro : 8.01.00.1248
Total Memory : 11GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz (4C 3.6GHz, 3.6GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : Gigabyte Core (Ivy Bridge) DRAM Controller 100MHz, 2x 6GB DIMM DDR3 1.6GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : G.Skill F3-12800CL9-4GBSR2 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-28 5-37-12-6)
Video System
Monitor/Panel : LG
(1440x900, 25.7")
Monitor/Panel : Dell Computer DELL 1908FP
(1280x1024, 19.1")
Monitor/Panel : Samsung SAMSUNG
(1920x1080, 7.2")
Video Adapter : Intel(R) HD Graphics (6CU 48SP SM5.0 350MHz/1.1GHz, 1GB DDR3 1.6GHz 128-bit, Integrated Graphics)
Video Adapter : AMD Radeon HD 7700 Series (10CU 640SP SM5.0 1GHz, 2GB DDR5 4.6GHz 128-bit, PCIe 3.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Radeon HD 7700 Series (640SP 10C 1GHz, 2GB DDR5 4.6GHz 128-bit)
Compute Shader Processor : AMD Radeon HD 7700 Series (640SP 10C 1GHz, 2GB DDR5 4.6GHz 128-bit)
Compute Shader Processor : Intel(R) HD Graphics (48SP 6C 350MHz/1.1GHz, 1GB DDR3 1.6GHz 128-bit, Integrated Graphics)
Storage Devices
Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm) : 2TB (C:)
Seagate ST3000DM001-1CH166 (3TB, SATA600, 3.5", 7200rpm) : 3TB (G:)
WDC WD7500AAKS-00RBA0 (750.2GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 699GB
WDC WD10EADS-00M2B0 (1TB, SATA300, 3.5", 32MB Cache) : 932GB (E:)
HGST HTS721010A9E630 (1TB, USB3/SATA600, 2.5", 7200rpm, 32MB Cache) : 932GB (H:)
Seagate ST3500630AS (500.1GB, USB2/SATA300, 3.5", 16MB Cache) : 466GB (K:)
TSSTcorp CDDVDW SH-224DB (SATA150, DVD+-RW, CD-RW) : N/A (D:)
Logical Storage Devices
System Reserved : 350MB (NTFS)
MediaDrive (G:) : 3TB (NTFS) @ Seagate ST3000DM001-1CH166 (3TB, SATA600, 3.5", 7200rpm)
DataStore (E:) : 932GB (NTFS) @ WDC WD10EADS-00M2B0 (1TB, SATA300, 3.5", 32MB Cache)
TOURO (H:) : 931GB (exFAT) @ HGST HTS721010A9E630 (1TB, USB3/SATA600, 2.5", 7200rpm, 32MB Cache)
FreeAgent (K:) : 466GB (NTFS) @ Seagate ST3500630AS (500.1GB, USB2/SATA300, 3.5", 16MB Cache)
Hard Disk (C:) : 2TB (NTFS) @ Seagate ST2000DM001-1CH164 (2TB, SATA600, 3.5", 7200rpm)
Optical Drive (D:) : N/A @ TSSTcorp CDDVDW SH-224DB (SATA150, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller 1 : Gigabyte Panther Point LPC Controller
LPC Legacy Controller 1 : ITE IT8728F
Audio Device : Gigabyte Panther Point High Definition Audio Controller
Audio Device : ASUS Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Disk Controller : Gigabyte Panther Point 6 port SATA AHCI Controller
USB Controller 1 : Gigabyte Panther Point USB xHCI Host Controller
USB Controller 2 : Gigabyte Panther Point USB Enhanced Host Controller #2
USB Controller 3 : Gigabyte Panther Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer v4 (600x600, Colour)
Printer : HP Officejet 4500 G510g-m (600x600, Colour)
Printer : HP Officejet 4500 G510g-m fax (200x200, Colour)
Printer : HP Officejet 4500 G510g-m (1200x1200, Colour)
Fax : Microsoft Shared Fax Driver (200x200)
Printer : Adobe PDF Converter (4000x4000, Colour)
Scanners and Cameras
Scanner : Hewlett-Packard 4500 G510g-m,192.168.5.35 (Scanner, 2400x2400, USB)
Sensors
Location : Microsoft Windows Location Provider (Location, Triangulation)
Peripherals
Media Player : Seagate FreeAgentDesktop (465.76GB)
Media Player : HGST (931.5GB)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps)
Network Adapter : TAP-Windows Adapter V9 (Ethernet, 10Mbps)
Operating System
Windows System : Microsoft Windows 8.1 Professional 6.03.9600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Good Luck!! hope this one helps!!
http://www.tomshardware.com/forum/newresponse/2272071
