Changing a sound card
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I'm replacing my existing sound card with something
considerably more sexy. How do I do it? Do I just turn off
the computer, pull out the old card, stick in the new one,
and turn on the computer? Or do I have to uninstall the old
card (a SoundMax) first from the Control Panel? Or what?
Help, please...
Bob
Kanyak's Doghouse
http://www.kanyak.com
The sound card should come with complete directions. You can also find
complete directions on the web site of the sound card manufacturer.
Modem Ani
"Opinicus" <gezgin@spamcop.net> wrote in message
news:1158ba5cpf3dmcc@news.supernews.com...
> Help, please...
> Bob
> Kanyak's Doghouse
Here is what I do:
1) in Control Panel ---> Add/Remove programs ---> Remove all software for
the sound card.
2) in Device Manager ---> Uninstall the drivers.
3) Power down your XP.
4) Carefully remove the old card (disable the sound card option in BIOS, if
the sound card is part of the motherboard).
5) Install the new sound card (note: insert in to the slot as far away
from your AGP video as possible.)
6) Start up XP and install the drivers when requested
This is to clean up un-used drivers.
> I'm replacing my existing sound card with something considerably more
> sexy. How do I do it? Do I just turn off the computer, pull out the old
> card, stick in the new one, and turn on the computer? Or do I have to
> uninstall the old card (a SoundMax) first from the Control Panel? Or what?
> Help, please...
> Bob
> Kanyak's Doghouse
> can also find
> manufacturer.
No problems there. I'm pretty sure I can install the new
one. The question is what to do about the old one. Do I just
rip it out:? Or uninstall it from the Control Panel? Or
what?
Bob
Kanyak's Doghouse
news:1158doblokvpsab@news.supernews.com...
> No problems there. I'm pretty sure I can install the new one. The question
> is what to do about the old one. Do I just rip it out:? Or uninstall it
> Bob
> Kanyak's Doghouse
You don't have to "rip it out", Bob. Just remove it more-or-less gently. But
remove it. And if there's any software program(s) listed for that old
soundcard in your Add or Remove Programs, just remove it.
Anna
> On Wed, 6 Apr 2005 21:41:07 +0300, "Opinicus" <gezgin@spamcop.net>
> Yup...pretty much that's it.
"Trent©" <trentsauder@hotmail.com> wrote in message
news:mf69519aoiifqj7isnhr1ojofhs7llubae@4ax.com...
> Not really.
> Just have the new cd handy when it calls for drivers for the new card.
> Have a nice one...
> Trent
The latter advice is *absolutely* wrong. By all means, remove your old sound
card. Not doing so has the potential for creating all kinds of problems in
the future. There is simply *no* advantage in retaining your old sound card
in your computer.
Anna
probably delete the drivers in Device Manager, power down, then pull out the
old card, install the new card, power up and let windows install the
drivers, and when prompted put the supplied drivers disk in for it to load
drivers from. Once the card is up and working, update the drivers from the
manufacturer's web site.
> Help, please...
> Bob
> Kanyak's Doghouse
