Changing Case For Components
Caelanbro
86
Alrighty, so this is kind of a n00b question, but I've never done this before so It's better to be safe than sorry...
I'm thinking about purchasing a new case for my PC; I have made sure that It matches all my PC component dimensions (ATX Mobo, Drive Bays e.t.c.), my question is: Will it still work fully if I swap all the other components over to the other case?
Thanks; Sorry for the newbie question... Just curious
Thanks!
Does that include all the HDD connecting to the exact same port?
Won't make a difference what sata port you connect the hard drive. Your mobo will see where the operating system is.
Awesome! Thankyou again, you helped heaps!
