Chkdsk problem
Mike
Splendid
Apr 1, 2004
3,865
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
System:
P3 700mhz, 60gb hdd, 384mbs of ram, XP pro with service
pack 2 and all other updates.
virus software upto date and clean, anti- spyware
software up to date and clean..
I have been trying to do a chkdsk /f for a while now but
everytime i do so I get an error.
I reboot the pc and the chkdsk info starts up, but almost
straight away it tells me that it connot complete
checking my disk because the volume is locked and cannot
be accessed?
I have tryed coing it from command promt and it went ok
if I just typed chkdsk but it would only scan read only,
then I tried chkdsk /f and it said again the volume is
locked and cannot be accessed.. chkdsk founds a lot of
errors so I need to fix it some how but I acnnot get my
head around it.
Can anyone please help?
Thanks very much
Mike wrote:
> System:
> be accessed?
> head around it.
> Thanks very much
If the drive you are trying to scan is c: then try this from the command
prompt before running chkdsk /f:
unlock c:
The reader should exercise normal caution and backup the Registry and
data files regularly, and especially before making any changes to their
PC, as well as performing regular virus and spyware scans. I am not
liable for problems or mishaps that occur from the reader using advice
posted here. No warranty, express or implied, is given with the posting
of this message.
>-----Original Message-----
>Mike wrote:
>> System:
service
but
almost
cannot
>> be accessed?
ok
only,
of
my
>> head around it.
>> Thanks very much
from the command
>unlock c:
Registry and
changes to their
scans. I am not
reader using advice
with the posting
>of this message.
Thanks for the reply but it had no effect.
this is the full error from the command promt window:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Neath>chkdsk /f
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N)
You're not by any chance running Zone alarm version 5.0,
are you? It was buggy and caused a problem such as you
are describing.
If you are running that version, go to zonelabs.com and
dl the current version.
>>Mike wrote:
>>> System:
>service
>but
Have you installed SP2 yet? That might fix it.
of this message.
