Hi
As the title says, I am going to buy myself a monitor in the near future. As of now I have narrowed it down to mainly two monitors.
BenQ 24" 3D LED XL2420T (http://www.newegg.com/Product/Product.aspx?Item=N82E16824014350)
Eizo 23" LCD Foris FS2333-BK (http://www.newegg.com/Product/Product.aspx?Item=N82E16824136117)
As you might understand from my two options, color is an important factor of choice. The monitor will also be used for gaming and that to is an important factor. So my problem here is to find that sweet spot between the best gaming experience and the best visual experience. So my question to you, what should I choose? What is your advice, why, why not? Do you personally have any experience with any of the monitors? What do you think will give the best experience overall? If you have a better option please share it
And does anyone know how big the difference is between IPS and Led in color? I have a HTC One X as a reference for an IPS screen,
Thanks in advance for you help
Martin
