Question Chronic Wired Connection Issues
cmill78
59
For the last 3 years I have had connection issues ONLY on my wired connection. All wireless devices do not experience ANY issues. These issues do not happen if I have a VPN turned on, but that isn't always practical for speed reasons. It isn't permanent. A simple reload or three immediately brings me to where I was going. However, it becomes frustrating when logging into games, staying connected to certain streaming services, or making any purchases online. Basically, not life altering but annoying. Here are the things I have tried to resolve the issue:
- Uninstalled the VPN via REVO (twice), deleted all files associated with it, and reinstalled a different VPN and had some issues so I repeated the uninstall.
- Updated all relevant devices, drivers, programs (i.e.; Ethernet, GPU, BIOS, router firmware, etc...).
- Restarted modem and router (several times).
- Confirmed through ISP that their modem is working properly.
- Changed ethernet cables.
- Ran network commands (netsh winsock reset, netsh int ip reset, ipconfig /release, ipconfig /renew, ipconfig /flushdns).
- Uninstalled Ethernet Network Adapter driver and restarted Windows.
- Tinkered with 'Speed/Duplex' settings on Windows and router.
- Disabled 'Dynamic QoS' within router.
My router is a Nighthawk X6 R8000 and it seems to be working fine otherwise, though it is a little over 4 years old. My motherboard is an MSI B450 Tomahawk Max and I am using the Ethernet port on that motherboard.
The only thing I haven't done yet is a complete Network Reset. I was told it should be a "last resort" so I came here to see if I missed anything before taking that step. Any help would be greatly appreciated.
Is that the full "ipconfig /all"?
Connection path being the following line diagram where ----> represents an Ethernet cable:
ISP === (coax) ===> Modem [Yellow port]---->[WAN Port] Router [LAN Ports] ----> Wired devices
and
~~~~> wireless devices.
Feel free to edit and correct my line diagram.
May be going in circles here....
Try disabling IPv6
Change the DNS Servers to Google at 8.8.8.8 and 8.8.4.4
How do you log out?
I 'Switch User' and leave the PC running in the rare occasion my wife needs use of the PC. I technically do not log out at all unless I am shutting the machine down for cleaning or will be away for most of the day. I have always done this on every machine I have built since my first build in 2002.
Thought being that some update or housekeeping process is being prematurely interrupted.
When I 'Switch User', I usually only have my e-mail client (thunderbird) and sound settings open (I use headphones a lot). However, even when I close them out during 'Switch User' the problem still occurs. Plus I have done it this way much longer than the problem has existed.
What about agt.exe?
Is it expected that agt .exe would be somewhere launched and thus running?
Did a quick look through the previous posts: did not note any AV/Malware scans.
Has there been any recent scans?
Literally did a Malware scan right before posting this and it returned nothing. Windows Defender returned no issues. Running spyware scan now. Last time I ran scans was 91 days ago.
As far as agt.exe, I do not see it running in my processes currently. However, I searched the drive for it and it shows 13 entries of 'AppCrash' between May 30th and yesterday. However, this connectivity problem has existed longer than that. Apparently it is tied to the program MSI Live. This is the program that came with my mobo and is used to update the bios, as well as any other MSI product, though I use it only to check for mobo updates. Last tiime I used this program was in June.
I would remove that application while sorting through this ordeal.
Modem: make and model?
Router = Nighthawk X6 R8000
How are the modem and router connected - what ports?
Run "ipconfig /all" (without quotes) via the Command Prompt.
Copy and paste the full results in your next post.
The modem is an Arris CM3200. I've had it for a while (beyond 5 years) and the cable company says it is operating fine. There is only one port on the modem (other than the cable jack and power). It is hardwired to the router with CAT 6 to the specified port on the router.
Here are the results:
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet 3:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe 2.5GbE Family Controller
Physical Address. . . . . . . . . : 74-FE-CE-0E-F9-4A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller #2
Physical Address. . . . . . . . . : 00-D8-61-AB-1B-F6
Link-local IPv6 Address . . . . . : fe80::a2e6:78c6:f0e9:3e97%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, July 15, 2024 10:48:31 PM
Lease Expires . . . . . . . . . . : Friday, July 19, 2024 10:48:33 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 369154145
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-AE-02-BE-00-D8-61-AB-1B-F6
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
and
Try disabling IPv6
ISP === (coax) ===> Modem [Yellow port]---->[WAN Port] Router [LAN Ports] ----> [LAN Port 1] Home PC |----->[LAN Port 2] XBox One
and
~~~~> [wireless devices] 2 Samsung phones, 1 Nintendo Switch 2 Roku devices, Canon Printer, 1 Amazon Tablet.
All ports have been used and tested throughout this process with no difference in them thus far.
I will do the suggestions and report back tomorrow.
Just noticed that my new ethernet card (a 2.5gb) is showing as such for the "Ethernet 3" connection that is not in use (and am not sure why it's listed) but it says I am using a different ethernet controller for my current connection even though it is plugged into the 2.5gb. Strange.
So far the connection has stayed stable. I know it hasn't quite been 24 hours but I've had a rare off day from work today, though I am going to wait to say for certain. The only difference I have seen so far is a slightly slower load time on web pages. Is that common with the Google DNS Server numbers?
Not to derail this thread so my comment only apply google DNS. Google DNS servers are some of the fastest one in existence.
It is not one server or even 1 location. They groups of servers in multiple cities all around the world. All these servers share the same IP like 8.8.8.8 Most people are less than 10ms away from the nearest google dns location.
DNS is a extremely simple function, basically a simple lookup in a table. In some cases google will have to ask another dns that really owns the domain if it does not have the data cached. Unless you are access very obscure web sites the data is likely on the google DNS server farms.
Reactions: Ralston18
Roughly 48 hours later and the problem seems to have gone away. I will keep monitoring but why did my previous DNS servers cause the issue? Is there something I did, or can avoid doing, to prevent the issue in the future?
From your "ipconfig /all" results:
That is your router. Not as capable as Google's multiple DNS Servers at 8.8.8.8 and 8.8.4.4
I now understand why the Google DNS servers are better, and more reliable thanks to bill001g's post and your links. Thank you very much.
I guess I'm just trying to figure out why the issue started happening as I have always used my routers' DNS for every router I've had without issue. Only the last 2+ years I've had this issue happen.
I do appreciate everyone that responded. It is very much appreciated.
