G
Guest
Guest
Just got a used AMD Duron 600. I am getting ready to install thid CPU and FOP32 HS..to my MB.
Question:
The CPU core area has an old layer of thermal compound(arctic silver?) and I was wondering whether I need to clean the old residue off the cpu...before applying a new clean layer of Arctic silver compound?
Any tips on how to clean cpu?
Or should I leave alone and just add more thermal compound?
Also, should I use the thermal tape that came with the HS too ? or scrape the tape off..and just use the Arctic silver.
Thanks In advance
JW
Question:
Thanks In advance
JW
