Cleaning flat secreen monitor
jeff
1,172
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi group,
I'm a Dell owner, but I have a question about cleaning a flat screen
monitor I recently bought to go with my Dell.
I tried using those pre-moistened, alcohol free wipes that you can buy,
but it left streak marks on my monitor. Is there a better way to clean
these things? What do you folks do?
Thanks in advance for your help,
Jeff
"Jeff" <nospamever@cox.net> wrote in message
news:VXkZd.25117$KK5.12855@fed1read03...
> Hi group,
> Jeff
http://premiersupport.dell.com/support/topics/global.aspx/support/kb/en/document?dn=FA1011125#step1
C.
Jeff wrote:
> Hi group,
> buy, but it left streak marks on my monitor. Is there a better way to
> clean these things? What do you folks do?
> Jeff
I always thought ispropyl alcohol was good for that, but in some places
I read it can yellow the display. Where I have read that, the suggestion
is to use ethel alcohol. I've also read just the opposite.
What I use and have never seen anything against is diswashing liquid
(Dawn, etc.). Dampen a clean soft cloth with dishwashing liquid and
water. Clean screen. With clean soft cloth moistened with water only,
wipe off solution. Then dry with a clean soft cloth.
I've been using this for several years on my portable system with no
problems. And no streaks.
Of course, turn off system before cleaning, just in case.
Jeff wrote:
> Hi group,
> Jeff
Get yourself an Optical Grade Cloth, the type of material that oakley
sunglasses come with. You should be able to buy one from an optometrist
or a Photographics store. Then to clean the screen just wipe it gently
with the cloth. No need to use any chemicals.
ricardo
ricardo wrote:
> Jeff wrote:
>> Hi group,
>> Jeff
Thanks, I was wondering where I could find the microfiber cloths.
These days, it might very well be the household cleaning section of a large
super market or department store. 🙂 As for cleaning with these things -
they say they get more efficient after a cycle in the good ol' washing
machine first. Use dry, or juuust slightly moist, if there's dried-in stuff
you need to get rid of. You could add a drop of dish-washing detergent too,
though it's often overkill. Microfiber cloths are crazy effective even
without it.
On Wed, 16 Mar 2005 20:01:14 -0500, Sparky Singer <Sparky@moon.sun.org>
I bought mine at CompUSA: 3M Microfiber Electronics Cloth.
<<<SgtRich>>>
Desktop: Dimension 8400
Notebook: Dimension 8600
Both running Microsoft Windows XP Home Edition
