Hello
I am having problems upgrading from ssd to nvme. If i connect the nvme through its dedicated bay the computer will not boot. I moved the old ssd to all other sata ports as i read that with some motherboards installing the nvme would turn off sata 3.0. I checked that the booting order was correct. So i am unable to clone the ssd using windows.
I set up a bootable usb with clonezilla in it. I booted up clonezilla and cloned the old ssd to the new nvme, it seemed to work. Then i disconnected the old ssd and the clonezilla usb from the computer and powered it up. I made sure at the bios that no other disk was connected and that the nvme was the first and only choice. The computer would not boot up. Something like "wait while the system is repairing" came up, i forget the exact words.
My system:
Plexhd x79 turbo 1.03 motherboard (i have no manual and i am unable to find one on the web)
Kingston a400 240gb ssd (around 80% of its space its being used)
Xeon e5 2689
16 gb ram
Rx 590
Nzxt 700w psu
The nvme is a crucial p5 500gb
Any ideas why clonezilla didnt work?
Is there any other way to migrate to the nvme?
Thanks!
My system:
Xeon e5 2689
16 gb ram
Rx 590
Nzxt 700w psu
Thanks!
