club 60 help hdrive help
steve
2,366
Archived from groups: alt.sys.pc-clone.packardbell (More info?)
Hi, My original hard drive has failed and I had to buy another a hitachi 80
Gb unfortunately it is not seen in the BIOS, I would imagine that the bios
is too old to recognise the size of this new drive.
I looked at IBM /Hitachi website to see if I can get a hard drive manager
that would be able to trick the bios to get it installedbut they say that
they have stopped it.
Is there any other software I could use?
or could someone please tell me a procedure so I can mount this drive.
regards Steve
"Steve" <misxccp@blueyonder.co.uk> wrote in message
news:bG9Hc.1039$vE1.9731095@news-text.cableinet.net...
80
manager
> regards Steve
Go to Google and look up "Hard Drive Controller Cards" a few companies make
them (Promise if they are still in business was one) you place the card in
available PCI slot in your system. You then connect the new larger drive in
the controller on the card. It has its own BIOS so it will be able to use
the full capacity of the new hard drive. Also follow the directions and you
should have no problem.
Ben Myers may have a card or even know which to buy since he is in that
computer business.
NEVER**** use any BIOS overlay program since many times it causes more harm
than good. Don't let anyone tell you that its OK to do so. The programs like
EZ-Drive or Ontrack, or MaxiBlast were made by the hard drive companies in
order for them to sell the devices. Don't use them.
Elector
Well said, Elector. Let me add that some IDE/ATAPI hard drive controller cards
require a later revision of PCI, usually 2.1, than is designed into some of the
older Pentium class motherboards. Best to check specs before buying, then buy
from a seller with a no-strings 100% money back return policy, if possible.
But no overlay software. Ever... Ben Myers
>80
>manager
>> regards Steve
>computer business.
>Elector
beleive this is his motherboard
could be wrong
http://pt.giga-byte.com/MotherBoard/Products/Products_GA-6WMM7.htm
It should be compatible with a card
Of course if it was running Windows
Sandra Sisoft would tell
<ben_myers_spam_me_not @ charter.net (Ben Myers)> wrote in message
news:40ed38ed.945639@news.charter.net...
cards
of the
buy
possible.
hitachi
> >80
bios
> >manager
that
> >> regards Steve
make
in
in
you
> >computer business.
harm
like
in
> >Elector
Yeah, that's a newer board. Probably a Promise, SIIG, or similar card would be
OK in it... Ben
>could be wrong
>cards
>of the
>buy
>possible.
>hitachi
>> >80
>bios
>> >manager
>that
>> >> regards Steve
>make
>in
>in
>you
>> >computer business.
>harm
>like
>in
>> >Elector
Thank you for your help, you are all know you stuff, BTW the motherboard is
a GA-6WMM7 I will look for a PCI IDE/ATAPI hard drive controller..
Steve
"metronid" <metronid@comcast.net> wrote in message
news:ndidnYjCsKW2-nDdRVn-jg@comcast.com...
> could be wrong
controller
> cards
> of the
then
> buy
> possible.
> hitachi
> > >80
> bios
> > >manager
> that
drive.
> > >> regards Steve
> make
> in
drive
> in
use
> you
> > >computer business.
> harm
> like
> in
> > >Elector
