Question CMOS Battery Connector
May 20, 2020
5
Hey guys, just want to ask if the white connector is standardized?
I asked a seller (advertising that he's selling Dell OEMs) online if his battery is compatible and he said no :O
My laptop is a Dell Latitude E6520
I don't have the skills to solder/mess around with the wires and local sellers don't carry the exact product
yea my battery is kaput for sure
Yes there are tons on ebay and aliexpress but they are expensive and have long transit times compared to local sellers
The problem I have with local sellers is all the connectors look the same to me but I asked a bunch and all of them said that its not compatible
Hence my question
You can just change the battery inside, buy 3.3v coin battery, open the plastic and replace, that way you dont have to replace the connector aswell
Make sure + and - are CORRECT
don't have the skill to make my own, I just want to know if the connector is standardized so I can buy something that looks 90% like the one I got even though the model number is not listed in the listing
