Hi guys,
I have 2 Fiber service with the same spec (300 Mb up/ 300 Mb down) at my place.
Using two different modems I could Load Balance the Services using my Asus TuF-AX5400 in Dual WAN mode and Load Balance with 1:1 structure. The total output was 540 Mb up and 500 Mb down which looks perfect.
I have spent a good part of my last week doing the same thing using one GPON (Fiber Modem) instead of two of them.
I can set several WAN connections on my fiber optic modem with different service credentials (PPPoE credentials user/pass) and the WAN connections showing 2 different WAN IP's are connected and all. But when I connect two different LAN ports, which assigned to different VLAN/WANs, it seems like that the Load Balancing does not work as expected.
At this stage, ASUS TuF-AX5400 router (my Load Balancing router) showing 2 WANs are connected properly and the Internet is up and running but the total throughput is showing just the download speed of 300 Mb up and 300 Mb down. It means that only one service is serving load balancer.
Is there anything I have missed?
I already had tried several scenarios like disabling NAT's, assigning Static IP/gateways and so on... but the results was the same.
Two modem works flawlessly but two connection from one modem (two different WAN services) not.
Any help/suggestion is highly appreciated.
Thanks.
Thanks.
