G
Guest
Guest
Archived from groups: alt.comp.periphs.dcameras (More info?)
I have a fairly old Fujifilm 256MB CF card that have worked for the
past year in both my parent's camera and in my PDA. But in the past 2
weeks it has consistiently refused to work properly.
If I put it into the card reader (2 different model) the activity
light blinks and any other memory card I may have inserted dissapears
off the explorer (ie SD or MS card doesn't show up anymore) but when I
remove the CF card, the reader works fine.
When I used it in the camera I am still able to take picture & view
them but it won't let me delete (unknown error) and won't let me
format (card not present error) forcing me to remove and reinsert the
card before I can use it again.
When I used it into the PDA I can add and delete files either directly
in the PDA or from the desktop PC through the USB cradle but I can't
format the card at all.
I originally thought the card had expired (all Flash ROM can only
handle so many rewites, in the million range before it stops working)
but I was still able to add and delete fine in PDA and add only in the
camera.
I have a 16MB crd (came with camera), 128MB card, and 1GB card (bought
it just for my PDA for MP3) and they all work fine in PDA, both card
readers, and in camera.
Any idea what is going on? I would think a reformat would solve this
but I can't reformat it for some reason.
When you hear the toilet flush, and hear the words "uh oh", it's already
too late. - by anonymous Mother in Austin, TX
To reply, replace digi.mon with phreaker.net
camera.
