Question Compatibility Issue
Mar 28, 2019
Hi everybody, I'm currently drafting a build for my first gaming rig and would greatly appreciate some advise on compatibility, apologies in advance if this is the wrong area to ask.
The build is as follows:
Case
THERMALTAKE VIEW 71 RGB TEMPERED GLASS GAMING CASE
Processor (CPU)
Intel® Core™ i9 Eight Core Processor i9-9900K (3.6GHz) 16MB Cache
Motherboard
ASUS® TUF Z370-PLUS GAMING II: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
Memory (RAM)
32GB Corsair VENGEANCE DDR4 3000MHz (2 x 16GB)
Graphics Card
11GB NVIDIA GEFORCE RTX 2080 Ti - HDMI, 3x DP GeForce - RTX VR Ready!
1st Storage Drive
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE
1st M.2 SSD Drive
256GB INTEL® 760p M.2 NVMe PCIe SSD (upto 3210MB/sR | 1315MB/sW)
Power Supply
CORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY
Processor Cooling
Corsair H115i PRO Hydro Series High Performance CPU Cooler
Sound Card
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking
WIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
USB/Thunderbolt Options
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System
Genuine Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001]
The vast majority of this was created for me by the following website https://www.pcspecialist.co.uk
Thank you in advance for any assistance in determing if this set up is compatible, I am completely new to PC and know very little regarding hardware still.
I don't see any serious compatibility issues with that system of yours....It's a decent RIG, imo. Go for it.
Would this build be more compatible?
Case
Processor (CPU)
Motherboard
ASUS® ROG MAXIMUS XI HERO: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
Memory (RAM)
32GB Corsair VENGEANCE DDR4 3200MHz (4 x 8GB)
Graphics Card
11GB ASUS ROG STRIX GEFORCE RTX 2080 Ti - HDMI, DP
1st Storage Drive
1st M.2 SSD Drive
DVD/BLU-RAY Drive
NOT REQUIRED
Power Supply
CORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable
1 x 1 Metre UK Power Cable (Kettle Lead)
Processor Cooling
Corsair H115i PRO Cooler w/ PCS Ultra Quiet Fans
Thermal Paste
COOLER MASTER MASTERGEL MAKER THERMAL COMPOUND
Sound Card
WIRELESS 802.11 AC1200 867Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD
Operating System
Thank you again for your kind assistance.
Z370 Chipset motherboards often need a CPU that works with early BIOS versions to flash the BIOS to a version that supports the use of 9th Gen Intel Core, Pentium Gold and Celeron Processors.
Thank you for the information, would my updated build using a ASUS® ROG MAXIMUS XI HERO: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready work without any issues?
I've checked on the parts picker section and nothing flags as incompatible.
