Compatibility? With monitor stand
Hussein9704
Commendable
Jan 3, 2017
32
Hey im just asking If the Mount-It! Dual Monitor Mount Desk Stand for LCD LED Computer
Is compatible With the Asus rog swift pg258q and the Acer K242HQL
Like, With the size, Weight and right screws
Because In the manual for the Asus screen it says "use only UL certified monitor stand"
So is it compatible with as I said weight, screws, right holes for fitting it, and size
And is it UL certified?
this stand could support up to 27 inch screeen and it have vase monut for the 75 100 mm set up so the asus will fit on with the acer took me 1 min to find all details on google .
Hussein9704
Commendable
Jan 3, 2017
32
So If i use integrated graphics In motherboard With gpu on other screen Will there be distortion ?
And How Can i fix it
Hussein9704
Commendable
Jan 3, 2017
32
so i know one that has a 60 hz monitor and a 144 but same input lagg but he has no problems and both conmectet til gpu
