Question Compatible?...Help
Sep 10, 2019
This is my first build. I want to use Ryzen 3 3200G with a cheap B450 chipset board. My choice Gigabyte B450M S2H. Is Gigabyte B450M S2H compatible with Ryzen 3 3200G without BIOS update? . Plz help. I don't want to BIOS update. pcpartpicker not showing Gigabyte B450M S2H in motherboard option.
Gigabyte B450M-S2H CPU Support List
Unless the motherboard comes with the latest BIOS already installed (no way of telling), then no. While the CPU is compatible, it's likely only after a BIOS update. If you're not willing to perform a BIOS update, the best option for you would be the Ryzen 3 2200G which is natively compatible with the initial BIOS.
-Wolf sends
