Good Evening,
I previously made a post where I thought my GPU was the problem, which it was. I replaced it with an MLLSE Radeon RX580 8GB SP2048, but I'm still encountering the same issues: no BIOS or POST, although everything is running (GPU fans, CPU fans, etc.). The only indicator is the EZ Debug Light on the right side, which blinks under the CPU.
At first, I thought it meant my CPU cooler was screwed too tightly, so I loosened it slightly (but not too loose). However, the light kept blinking. I then tried booting with only one stick of RAM, but that didn't work either. I went to the MSI website and downloaded the latest BIOS file and performed a BIOS flash, but I still got no BIOS or POST— just no signal and the white light on the EZ Debug under the CPU.
Does this mean my CPU is broken or unsupported?
Any help would be appreciated.
Specs:
CPU: AMD Ryzen 5 3600
GPU: AMD Radeon RX 580 by MLLSE
RAM: 32GB G.Skill RipJaws V CL18 DDR4-3600
Motherboard: MSI B550 A-Pro
PSU: Enerman M AXPRO II 500W (I also swapped it to a be quiet! 520W PSU, but got the same result)
Storage: Samsung 980 Pro M.2 SSD
Case: Fractal Define R4
Specs:
